Johnny65 Established Member Joined 20 Sep 2020 Messages 73 Reaction score 18 Location Lowestoft 31 Jul 2023 #1 Hi all, My original planer blades are, 210mm x 16.5mm x 1.5mm Can I use, 210mm x 18mm x 3mm I can't get the original size quickly so wondered if a slightly bigger size will fit.
S sams93 Established Member Joined 3 May 2022 Messages 621 Reaction score 328 Location East Sussex 31 Jul 2023 #2 I usually get mine sharpened rather than replace, but do have a spare set. Looks like you can get new ones of your original dimensions here: https://www.toolite.org.uk/charnwood-w5881-planer-knives-15mm-p-56950.html https://solenttools.co.uk/product/s...esser-blades-compatible-with-titan-ttb342bte/ https://www.amazon.co.uk/LMEIL-16-5mm-Planer-Einhell-Woodworking/dp/B09YMKD1S2 https://www.amazon.co.uk/FEIDER-F1120RD-2-Planer-Blades-16-5/dp/B07MGSM3K1
Sachakins The most wasted of days is one without woodwork Joined 4 Apr 2020 Messages 2,326 Reaction score 1,651 Location Liverpool 31 Jul 2023 #3 It depends, if you can't get the ne blade down further in holder, then the top blade edge will be above your outfield table, so unless you can avoid this then I'd not use them.
