studders
I believe you Paul, I just can't get my head around the 'why'.
I need a darkened room.
:? :? ...if you put downward pressure on the end of the plane as it finishes the stroke, the board will tend to be more convex, that's all I was trying to get acrossmtr1":2qtiugk9 said:woodbloke":2qtiugk9 said:What MrC and Paul say may be fundamentally correct, but pushing down at the end of stroke will only compound the convexity...vertical downward pressure should be eased to almost zero at the end of the board - Robmtr1":2qtiugk9 said:I can confirm that's true, I wondered if it's because you push down hardish at the start, go into a kinda cruise mode through the cut, then push down at the end of the board again? Might be why my grandfather added lead to the front of his no8, to minimise the convexness of shooting by hand?
Sigh.
Ahhh, that would explain it Matt...it's just that it didn't appear to be explained that way, or it was me mis-interpretining the information. Probably me...the nuances of t'interweb - Robmatthewwh":2mtw01t0 said:Rob, I think Mark is referring to the transfer of weight to the tail at the end of the stroke to ensure that it doesn't lift - not pressing down on the front again.
