SkinnyB
At work recently they were throwing out some Phenolic cubical doors. I kept one in the hope of turning into a router table top. I had heard it is pretty hard to cut. I thought I would give it ago anyway. I had been looking at purchasing a commercial Phenolic pre-made router top. However they fetched upwards of £300 for the size I was after.
First job was to cut it down to 600x1200mm (its 16mm thick).
The track saw did and ok job with light 3mm passes. I then switched to the table saw which cut far better. Slow going but left a reasonable edge.
Next was to start routing out a place the router plate to sit. I am using my own 8mm Acrylic plate which I have designed. It has been cnc and laser cut. It has 8 grub screw levelling points. 100mm opening. It is just a little larger than the base on the Triton router so I should not see any sagging once it is bolted to the base of the router.
I cnc cut a template and used a flush trim template bit to edge my way down to 8.5mm. I used a cheap tct cutter as from what I read the material can dull blades fairly quick. I went down 1mm at a time until I reached the correct depth.
IMG_8104 by jamie skinner, on Flickr
Then I switched to a 1/2 hss upcut bit as I needed a fairly long bit to reach. This felt a little slower going but with 1mm depth of cut I got there and left a nice edge. I used a bushing to offset the bit.
IMG_5362 by jamie skinner, on Flickr
Next I setup my double dado jig to cut the slots for the fence mounting. It has 30mm slots in which a 30mm bushing on a router fits into. My first mistake here is that I should have made this cut from the bottom as I had to flip it around and cut a wider recess int he back. Luckily it worked well anyway.
IMG_5365 by jamie skinner, on Flickr
Clamped in place. I used a bar clamp to set the stop not he opposite end.
IMG_5366 by jamie skinner, on Flickr
IMG_5367 by jamie skinner, on Flickr
Flipped and recessed.
IMG_5368 by jamie skinner, on Flickr
Next I needed to create a small hole for the handle which raises and lower the router. Second mistake is that I made it in the wrong place. It gets covered by the fence... I still have easy access under the router table so its not a big issue. I will more than likely rate the router to put it in a better spot.
IMG_5370 by jamie skinner, on Flickr
IMG_5371 by jamie skinner, on Flickr
IMG_5372 by jamie skinner, on Flickr
Adjusting the router plate height.
IMG_5373 by jamie skinner, on Flickr
Drilling holes to secure the plate. What I really should have done here was drill under sized holes and then tapped some traps into the top.
IMG_5375 by jamie skinner, on Flickr
IMG_5376 by jamie skinner, on Flickr
Thats as far as I have got. I have some left over to make a new split fence. I am going to add two 1/4 routers on the left side for a permanent chamfer and rounder over bit. I need to add some support under the top to stop the top from sagging. Over all it is far better and flatter the the oak worktop I was using before.
IMG_5378 by jamie skinner, on Flickr
![](https://proxy.imagearchive.com/7a3/7a3a4ea3e75ce28ac02424e01205b095.jpg)
![](https://proxy.imagearchive.com/db3/db3b8280e201681a5c300ac72c751d6c.jpg)
![](https://proxy.imagearchive.com/f58/f584104dbe6d9ce4aba0ef6ca3ecd0ef.jpg)
![](https://proxy.imagearchive.com/31a/31a3b4014ae3548e9ccc8972a357d0e7.jpg)
![](https://proxy.imagearchive.com/b16/b16f897bcb5582051d0c03d5ae43730d.jpg)
![](https://proxy.imagearchive.com/003/00317fb8f43d1c8073e9bfaab18950c6.jpg)
![](https://proxy.imagearchive.com/afc/afc9efe2a4fccb4fc98d5ac8d82f0c69.jpg)
![](https://proxy.imagearchive.com/488/48870f06fb208806f81abc9185eca633.jpg)
![](https://proxy.imagearchive.com/0b7/0b71dac8394a560795c1e4849f216ba8.jpg)
![](https://proxy.imagearchive.com/0ee/0ee9db2043b430d76ba3a89b642257c2.jpg)
![](https://proxy.imagearchive.com/cb1/cb1f2f49bbcba4ce9cf64f76e843aa22.jpg)
![](https://proxy.imagearchive.com/50d/50de4492e5bc27b9503a4e184946d6d3.jpg)
![](https://proxy.imagearchive.com/035/03573fbff0e0d8c1b75cb0fbf9f48ea0.jpg)
