I have a query about ovolo cutters for a Record 405. Since it’s hard to find these online I was thinking about making some. The manuals available online show either three optional cutters 1/4, 5/16 and 3/8 for the older model plane or two supplied cutters 1/4 and 3/8 for newer models. Unfortunately the manuals are no guide as to size and profile, the later model illustration for the small and large cutters looks as though it has re-used the images from the previous manual for the small and middle-size cutters.
I have one ovolo cutter, described online when I bought it as 8mm so I’m assuming it’s the 5/16(7.93mm) one and that the cutter measurement is the horizontal distance. If I'm wrong in the way the cutter is measured then please correct me.
I’ve ordered a bit of 3mm O1 flat stock to make the other ovolo cutter sizes. The dotted red line in the diagram above would be the line of the skate and clearly this must stay outside the curved section. Therefore to make a larger cutter I’m assuming I expand uniformly 1.5mm each side of the dotted red line for the larger 3/8 cutter and similarly reduce for the smaller 1/4 cutter.
Something like the blue lines for the larger cutter in the diagram below.
From the illustrations it looks as if dimensions should be the same along the cutter with the blade bulge staying at a constant 29mm depth and that the width is the only variable.
If anyone has a set of three cutters and can photograph them or even just say if my assumptions are wrong and the length of the wide head part varies as well as the width it would be a help.
The bevel doesn’t look very complicated, I sharpened the 5/16 one with a piece of wet and dry on a dowel so after rough shaping with a rotary stone I’ll use some coarse sandpaper on a dowel to establish the bevel before heat treatment.
Jim
![newandoldmanual.jpg newandoldmanual.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/31/31946-newandoldmanual.jpg)
![record516ovolo.jpg record516ovolo.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/31/31947-record516ovolo.jpg)
![bigger.jpg bigger.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/31/31948-bigger.jpg)
![record516ovolobevel.jpg record516ovolobevel.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/31/31949-record516ovolobevel.jpg)
Jim
