So I am in the middle of redecorating the hallway, stairs and landing.
This has been a long on going project due to funds and time but up to yet I've made some under stairs pull out cupboards and started to enclose the boiler.
The next part is to replace the original loose and badly damaged down stairs newel post for a solid oak newel.
Here's a couple of pictures of the task in hand.
Now as can see the stringer is badly damaged from the loose newel, the first picture shows the damaged tenon which the bottom 'tooth' has been pushed back in.
I plan to router out the damaged timber to the line on the first picture and glue on a new section of timber to replace the tenon, I'm not cutting off the stringer but taking away the left half as shown on the second picture.
What glue would you suggest to use for gluing on a new section, would a normal PVA work if its strongly clamped or screwed as well or should I be looking for a PU glue?
![IMG_20190416_143439-1395x1395.jpg IMG_20190416_143439-1395x1395.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/59/59845-IMG-20190416-143439-1395x1395.jpg)
![IMG_20190416_143508-1395x1395.jpg IMG_20190416_143508-1395x1395.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/59/59844-IMG-20190416-143508-1395x1395.jpg)
