Newbie - quandry
gjhimages
14 Oct 2016
lancs
Hi
i first posted a couple of weeks ago i have purchased an Awfs16, i also fitted the Olson quick change bits to replace the not very good axminster supplied pinless blade holders
my problem now is its a right pain to do internal cuts. to feed the blade properly you have to take the side off to ensure the blade holder still sits it the bracket of the lower arm
it xmas so
bearing in mind i am a hobbyist should i trreat myself to a hegner multicut 1 , single speed , or axminster awfs18?
would i eventually need variable speed?
most posts say variable is most useful for thinner materials but with care would a single speed be ok?
i am looking at the multicut 1 mainly due to size and weight , i scroll in spare bedroom so space is limited
your thoughts or ideas would be appreciated
merry Xmas etc to all
Depends on the size of things you want to make ( Throat size ) I would go for the hegner multicut 1 , A quality machine , Variable speed is a nice addition , good for cutting brass , alloys perspex etc
Just my opinion others will disagree
Don't get me wrong there is nothing wrong with the awfs16 , as a beginner what i have done so far is acceptable and at the price £86 its a bargain
but to move on to more demanding tasks i think i need to change it
maybe i should have saved up first but was worried investing £300+ on a first saw seemed a bit daunting in case i lost interest before progressing
gjhimages":bdyc7avm said:
it xmas so
My advice would be go for variable 100%, for cutting thin and delicate work you will find it invaluable, it's especially worthwhile for people new to fretsawing but is also good for experienced users.
Variable speed does cost a considerable amount more on a Hegner this is due to the fact that Hegner uses induction motors on it's machines which makes them much quieter and a heck of a lot more reliable, unfortunately it is a lot more costly for speed control on induction motors than the more usual series wound carbon brush type motors.
However even though it will cost more at the outset these machines are built to last a lifetime and you will soon forget the extra money you laid out for variable speed as you enjoy using the saw whereas if you buy the single speed you will always wish perhaps you had spent that bit extra for the variable speed model.
You only buy a Hegner once, it will last for many many years so it pays to buy the best at the outset.
It is not economically possible to upgrade a Hegner after purchase (short of swapping the machine).
One thing I can tell you is that you will not regret buying a Hegner, I still find mine a joy to use after 17 years and both my Grandchildren (age 9 and 13) use it safely, it's one of those machines that are a pleasure to use unlike some other noisy dangerous machines one has in ones workshop. Also in the unlikely event that you get fed up with it they do command high second hand value if you wish to sell it. (you won't want to part with it though!) :)
thanks for that scrimper
although the awfs18 is slightly cheaper than the muticut 1 variable space is a problem (and the weight)
think hegner is the way to go
by the way - love the videos
there is an axminster place in Warrington which is less than 60 mins away
may go between xmas and new year to take a look, the awfs looks 'hegner' like except its not red
problem with hegner is either buy 'unseen' from them or yandles in somerset which is a fair old journey just to take a look
a friend of mine who lives in ROI has an excalibur , would be tempted if i saw one in the flesh
gjhimages":3lngcpdc said:
...should I treat myself to a hegner multicut 1 , single speed , or axminster awfs18?
None of the above. Get a 2nd hand Delta.
