Money Boxes
bernienufc
24 Nov 2013
northumberland
Its early days and i hope to get much better as time goes by, but managed to raise £120 for 6 of these for charity :lol:
Those are excellent.
I doff my hat to you sir. What a charitable thing to do.
When you say you hope to get better at them, what aspects do you want to improve?
Are the dogs scrollsawn?
Thanks for posting.
I for one look forward to hearing more about these if you have time.
All the best.
Adam.
Thanks for the compliments.
The dogs and the bowls and bones are done by scroll saw,the coin slot is too.
One thing i just learnt that has helped enormously was stack cutting, that made matching parts which made a big improvement.
I need to improve by learning how to use a router on the 'ash' plinth without scorching it. I need to learn about finishing using oils and waxes, but i think santa may be helping me on that one.
Take several thin cuts with your router, make the last cut with your very thin and make a few quick passes without stopping.
Andy
There is a 1/2" sq hardwood spar at ea end inside the kennel, i drilled a hole through them and through the plinth, i put a captive nut used from my model aircraft into the wood (as they have spikes that dig into the wood when tightened) and then recessed screws pass through the plinth into the kennel to hold it together. It has a felt base just to make it a bit safer for putting on furniture etc
HTH
