CroppyBoy1798
Forgive me if this sounds rediculous but I've always had an issue with maths and numbers and stuff so it's probably a relatively simple problem.
I'm using a product that requires a mix ratio of 9:1 by weight. But I've obviously gone wrong somewhere as I've run out of acid catalyst while I still have some of the high build in the tin!
I just can't get my head around it and can't find an online calculator.
So for instance if I pour out 330ml of the high build clear and the ratio is 9:1 by weight how much catalyst do I pour in? Is there a simple formula or quick method for working it out as I'd be using different amounts depending on the job.
Thanks![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
