Midi Lathes e.g. Jet1220, Axminster 1218vs
Brianp
10 Apr 2013
Kildare, Ireland
Hi guys,
Just looking to see what other users of the benchtop style lathe (e.g. Jet 1220, Axi 1218 etc) do with their lathes - I have one and i use it on a workbench, but find that it sometimes is a bit rattley for larger pieces, obviously especially if they're a bit uncentred.
Do others find that these lathes are better if bolted down? I do like to be able to maneouvre the lathe a little getting into bowls and that...
Thanks, as ever, for your thoughts!
my 1416vs is not bolted down
i know it should be and i am wary of the fact
if i do anything worrying i ensure it is "clamped down"
Steve
I have bench top POC as i aint got the room for a proper one i G clamp it with a little brecket i kmocked up. Sorry no pics im too ashaimed of my poky work area lol
Brian, Try fixing your lathe to a plywood or MDF sheet about 10-12mm thick, (countersink bolt heads on the underside)sized just a little larger than the lathe footprint all round, say 25-30mm.
This may then enable easier clamping to your bench top with bench dogs/hold down clamps or similar as you reposition it.
