Hey all,
I'm in a fortunate position where I have acquired more space in my workshop/studio, some of which I plan to fill with a new workbench.
I have a relatively clear idea of the tasks I want to use it for, but I'm looking to the crowd for pointers and experience with regards to the compatibility of different features. I'm concerned I might have conflicting ideals with regards to function.
Requirements of bench:
My main concern at this stage is whether to go for a sheet material top bench or a solid timber bench. Are my requirements conflicting in any way? I have a load of questions whirling round in my mind at the moment:
Im trying to be pragmatic with my approach to the bench design. I totally get the appeal of a solid wood traditional bench, it has bags more charm than MDF. But I dont want to get too drawn into the romantic ideas of shiny OTT roubo benches and the like you see on YouTube, if a modest and practical MDF top would serve my needs better. Especially with regards to material stability. We have an English style bench made of larch (I think) in the communal workshop and the top twists all over the place. Its a beefy beast of a bench but it's far from a flat surface.
On the contrary I want to create something substantial which will stand the test of time, and that I'm proud to use. Maybe having an MFT grid isn't actually needed at all, and I could get away with a few strategically placed dog holes in solid timber.
As a final point - I'm of the school of though that simple is usually best. I'd rather create a simple and effective solution than Frankenstein something together thats overly complicated and asking too much. If my ideal requirements are asking too much then please let me know. But with space still at a premium, I'm all for incorporating functions - if they work well together.
Apologies for the splurge of thoughts here! I'm hoping that people can chime in with their experience or advice if they've been in a similar position.
Thanks in advance for any input!
Calum
- House a router + lift
- Cross cut timber and sheet stock using track saw and rail
- Work holding
- Vise (I won a huge old record vise in an auction for £42 )
- Dog system (clamps/holdfasts etc)
- Apron with dog holes/clampability?
- House Festool dust extractor under work surface (dedicated for use with this bench - router fence, track saw, domino, sander etc)
- Storage drawers
- Generally hefty construction, I want to be able to bash stuff with a heavy mallet and hand plane boards without strength/stability issues.
- A truly flat surface (e.g. for checking chair leg lengths)
- Messy work (glue ups, finishing) - I have another bench for this
- Tool tray on bench top
- Is it silly to mount a router and lift in a solid wood bench top? My gut instinct says that mounting it in ply or mdf makes more sense. Would solid timber's expansion across the 298mm span of the aluminium insert plate cause issues? Would the seasonal twisting/cupping of timber cause an uneven router table surface?
- Would I even use an MFT style grid? I've not used one before, but it definitely looks handy. The way Dennis (Hooked on Wood) demonstrates the work holding capabilities of his design makes an MFT style grid seem very appealing. Also the range of accessories compatible with this system looks like it would increase the versatility of the bench going forward. Efficient and accurate cross cutting with a rail hinge and fence is one of the main appeals for me right now. However, I don't want to buy into the world of gimmicky shiny anodised gadgets. I'm only interested if these things have real benefit.
- Is an MFT grid possible in a solid wood design? If the system relies on a super accurate 96mm grid system, surely the natural expansion and contraction of solid timber would throw this out.
- Isn't mdf too soft for 'holdfast style' clamps? Ive read that the lateral forces from these clamps stretch/crush the holes and make the fit sloppy for use with dogs. Which makes sense to me.
- Rail clamps can only fit through 18mm, so anything thicker is a no-go with 'through-bench' dog hole clamping?
- Does inlaying a sacrificial strip into solid timber workbench top (for tracksaw) seem like a weird idea?
Calum
