i was trying to cut some mdf skirting board 69mm wide x 14mm thick at 45degree mitre, not having a suitable mitre block to hand.
saw in a book that a jigsaw could be used with baseplate set to 45degrees,and running the jigsaw base against a guide battern to cut skirting.
my b&decker jigsaw has variable speeds so tried with short metal cutting blade,but this seemed to overheat and the jigsaw blade wandered, then tried with 14tpi coarse blade with not better results regardless of speed/feed rate settings.
so tried with softwood offcut blade set vertical blade still wandered?? so not sure if better /differant quality blades would give better results.
thank you
thank you
