Mdf and pocket holes
phil2010
16 Sep 2010
Do you get a good fixing when using pocket holes for joining mdf.
Yes, done properly you get an excellent joint using suitable screws at the correct angle and depth.
I agree with backing up from biscuits.
Are you building a carcass from MDF?
I'd build an MDF carcass around a bisciut-jointed wooden frame. (Or at least around two frames of 2 x 2, (50mm square). One at the top and one at the base. Don't forget to plan for a kicking strip at the base.)
You could use a Domino to joint the frames but that depends on the depth of your pocket!
See if you can find Paul Levine's DVD (FWW Taunton) on building cabinets and you'll get some great ideas.
http://www.whsmith.co.uk/CatalogAndSear ... 0918804945
http://www.dm-tools.co.uk/product.php/sn/GMCDVD17
WHS seems cheapest but you might have to add VAT!
HTH
John :)
