Makita red router
Hunter 001
26 Feb 2017
Wiltshire
Looking for my first router for occasional use as a hoppy.
This red makita M3601 is about £60 at amazon,
http://www.makitauk.com/products/mt-ser ... outer.html
Specification are below which ate the same specification for the green one PR0900x but at double the price.
https://www.screwfix.com/p/makita-rp090 ... 240v/52281.
What do you recommend for very light use like once every few weeks.
Collet Capacity 1/4 or 3/8 "
Noise sound pressure91 dB(A)
Noise sound power102 dB(A)
Noise K factor3 dB(A)
Input Wattage 900 w
Plunge Capacity (Plunge) 0 - 35 mm
No Load Speed 27,000 rpm
Vibration K factor1.5 m/sec²
Vibration: Cutting MDF7.5 m/sec²
Net weight2.7 kg
Thanks Mike, yes I have decided to go for katsu after I had a recommendation
From a respectful member on here via Pm.
Glad you found the post acceptable, but I think that I was also respectful. :lol:
Mike
Mike
of course mike you are very respectful member too and thank you for your valuable
Advice.
MikeJhn have AIM said when they will get more in. Made a baby router table at the weekend, a friend dropped off a nice sheet of cast Aluminium and was only thing I could think of to make. Made it specifically for the Katsu but need to get another as now my static base machine is in the table and can't be bothered taking off the plunge base on the other one
I wont argue with that, but it does mean you will miss out on a lot of things in life.
Mike
Similar threads
