Racers":pmz44jul said:
Rorschach":pmz44jul said:
The key to doing it safely seems to be a long extension cord and a dead mans footswitch.
That won't save you, only the people who find your corpse.
Of course it will set up properly. The transformer is on a nice long cable plugged into a socket well away from the bench. A dead man switch is added in line too well away from the transformer. With the transformer unplugged you set up your wood and electrodes. You walk away, plug it and then use the switch to turn it on. When you think you are done or want to inspect you remove your foot from the switch, unplug the transformer and then walk over and check it.
You can of course do it without the deadman switch and just unplug every time, but this way you have 2 levels of power interruption.
The problem is people wanting to be too close to the action or probably doing it in small sheds. Be at least 6 feet away from the set up and make sure the plug is with you and nowhere near the transformer.
