Jig to hold timber when using Lock Mitre cutter.
Derek Willis.
2 Sep 2008
West Oxfordshire, under the Cotswolds.
Having a job to hold the board when doing the vertical cuts, I devised this jig, two sliding cramping devices to hold the board, (I will change to Bristol Levers when I get them), works very well.
derek.
I like this a lot, Derek. :) No big, awkward G-cramps to get in the way, it's adjustable and your hands are always shielded from the cutter.
Derek,
do you find you get a good finished mitre when using this cutter?
Have been thinking of getting one for my spindle moulder.
Mark.
Mark,
I use this cutter for long cabinet sides, where I make up frames for glazing and join this way, it keeps the symmetry going and I have found that if you set up right the finished joint is excellent, I don't think I wuld use it for box type joinery though.
Derek.
