I have the Jet 16-32 Drum sander and am mostly pleased with it, it is a well-built machine, the only letdown is the dreadful clips that hold the sandpaper rolls, they are a pain in the buttocks, it would be much better to have the sandpaper fixed with some sort of screw, that when tightened would stretch the sandpaper I also had a look at the Axminster drum sander, and the reviews for that are worse regarding the same clips problem
before I bought this I built my own using a metal drum I managed to get on eBay, this worked great but had no power feed table, and the drum had no spring clips so the sandpaper had to be hook and loop, with self-adhesive velcro attached to the drum, I never had any problem with this setup, so I am thinking of doing the same on the Jet, just go over the slots where the clips are, anyone got any views on this or some other ideas
