ByronBlack
Thanks for all the kind comments!
Bloonose - I'm not decided on this yet. I might not as I think it may be a little too fussy, espeically with the existing exposed joints, what do you think?, i'll sleep on it though and see how I feel tomorrow.
MTP - I did consider the taper on all four sides, but I like the legs with rectangular 'foot' so i'm not sure i'll do any more tapering, but again i'll think more on this I havn't got so far that I can't go back and do this, so i'll let the idea tick over and see where it goes
Lukey - the top isn't going to be installed like that - it's mearly to a get an idea of what it'll look like. The top you see will be inset into a mitred sycamore frame, it will be 'floating' on rebates that will create a 5mm gap between the iroko inset and the sycamore frame so this will be adequate for movement. It will also just be glued. I did consider using dowell pins to strengthen the frame, but I think it will be plenty strong as it's mostly decorative, not sure what you mean by 'overcut' dowels though - do you have a picture or diagram?
