Internal doors, how wide is the gap on skinned doors please?
pe2dave
2 Oct 2007
Peterborough, Cambs, UK
Cutting 1.5cm off the bottom of a door.
Depending on how much (if any) has been taken off, will need
new 'infill'.
I'd like to go down to do the job with a piece in hand?
Anyone know what width I need to cut to please?
TiA
Internal doors are around 35/36 mm thick but then you have to subtract the thickness of the two faces which will probably be around 1.5 - 2 mm each side . Best to visit and decide on the day . I’ve done them before ( from new) and just moved the end rail and re glued them back into the door .
Thanks for that. Measured at 30mm... but enough meat left on existing filler so didn't need it.
