Incannel or outcannel gouge?
pgrbff
29 Oct 2020
Langhe, Piemonte
I have never carved but I am about to attempt to make myself an infill mitre plane.
One of the videos I saw used an incannel gouge to shape the wedge but from what I can see outcannel seems more common.
Can someone explain how they differ in their use?
In cannel are often called scribing gouges a common use and the bevel is inside. Out cannel is with the bevel on the outside( like a carving gouge) joiners gouges in cannel/out cannel are often quite chunky.
I'm aware of the physical differences I'm more interested in knowing when you might use one over the other.
"the one with the long straight flat surface on the outside"
I assume by this you are just referring to the bevel being on the inside rather than the outside? There is no actual flat?
