midnightlunchbox":1shgaxfn said:Personally I would run the cut side over a planer and make it flat. Then I'd mount that side on the headstock and turn the usual chuck dovetail in the round (bottom) end. Then I'd reverse it and smooth out the natural void into a bowl. You'd have a nice natural look on the outside but an attractive, off centre bowl on the inside.
If you don't know, you may be wise to go with Marcross's suggestion.SPSlick":2oo5ogbt said:How would you mount it on the headstock?
midnightlunchbox":2rcwgovj said:Personally I would run the cut side over a planer and make it flat. Then I'd mount that side on the headstock and turn the usual chuck dovetail in the round (bottom) end. Then I'd reverse it and smooth out the natural void into a bowl. You'd have a nice natural look on the outside but an attractive, off centre bowl on the inside.
midnightlunchbox":1kfswilw said:Personally I would run the cut side over a planer and make it flat.
SPSlick":132yruca said:Yeah I'm thinking it's way too much for me now and in the forseeable future so I may try to sell it.
Any ideas what I should ask for it?
+1Bodrighy":30uzjyck said:as said you will get peanuts for it probably and regret it later.
