Racers
- Joined
- 22 Apr 2005
- Messages
- 9,172
- Reaction score
- 132
D_W":21iczagk said:Racers":21iczagk said:Problems with the hardness test, its not giving clear indentations some plastic deformation around the indentation which makes getting a reading difficult.
It was coming out between 600-700 Vickers which is 49-52 Rockwell C.
Looks like I will have to do some lapping and get it retested.
Put it on an oilstone. If it refuses to be abraded but is definitely HSS, that gives you a hurdle of 61-62 or so. Could be anything above that, but some judgement will tell you how far (anything approaching 65 will refuse to do anything other than be burnished on an oilstone unless it is the plainest of plain steels - and that won't be).
It is the laminated tool steel blade that I had tested, the HSS one had a line of brazing between the HSS and the rest of the blade.
