MitreKnown
I was wondering what people thought the easiest way to make the cut shown below. It's in a total length of >20m of timber (each piece about 2.4m). Dimensions in mm. My table saw can't cut 120mm, max 80mm I think, but it would be a difficult cut to make anyway as keeping the timber on its edge would be tricky. I guess I could clamp or screw an additional timber to it to give it a more stable footprint, but then I am still up against the 80mm maximum cut problem.
I don't fancy using a router as that will take a long time and create a huge amount of sawdust. I suppose if I use the table saw for 80mm worth of it, then the router only has to do the remaining 40mm.
Any bright ideas?
Any bright ideas?
![1669888680279.png 1669888680279.png](https://cdn.imagearchive.com/ukworkshop/data/attach/129/129310-1669888680279.png)
