Monkey Mark
I'm a hobbyist, and one on a very tight budget for that matter. I also like the idea of recycling/up-cycling and generally tinkering (I prefer to make something than buy it where possible).
For that reason I am, still, looking into making my own dust/chip extraction system and thought I'd put my musings into text. Maybe bouncing some ideas around may help myself and others.
Current situation:
At the moment I use a simple pneumatic vacuum cleaner for my extraction. It seems to do pretty well but struggles when I use my bench top planer and the noise, although not as loud as a conventional vacuum, can still become annoying after a while. It's also pretty old and it was second hand so I have no idea how long it will last me.
I've not yet added a cyclonic separator but whatever I do that will be one of the definite additions.
Environment:
My "workshop" is a single garage. It is also used for storing general DIY tools, my kids automotive tools & bikes and general rubbish which I'm slowly sifting through and disposing of - especially when the wife isn't looking :mrgreen:
It also has the tumble dryer in there and dust has been know to find its way through that.
Thoughts so far:
My garage is only small but that got me thinking that's a good and bad thing. Bad because I'm limited for space which is why I have not gone the usual root and bought an off the shelf dust/chip extractor. They can be quite big and I already struggle as it is. (Though if I got one cheap and woodchips I'd use that until I figured something out).
But good too as that means whatever system I use it won't have to be portable as all the machines will be in pretty close proximity to start with. The garage has a pitched roof, so there is the option of using some of the so far rarely used space up there.
I originally thought of using car radiator fans. They can be had cheap, run quiet and take little power. They could be doubled or trippled up in an enclosure for greater air flow.
This idea was quickly kicked to the curb though. After a little research I found out that although they can move quite a bit of air, they are no good when it comes to creating pressure. Whats more, when adding multiples in a single enclosure, the enclosure has to be "tuned" otherwise the internal buffeting between the fans can actually decrease the effectiveness to below that of one fan. So, car fans are out of the question. Though I may use one for a simple dust filter at some point.
I could look into making my own squirrel cage/centrifugal style fan. This could be effective and cheap however I don't yet think I have the tools or more importantly the skills required to make one effectively.
I could use pre-made centrifugal fans, perhaps from an industrial machine. I do have one from a warm air heating system but I don't this this will be powerful enough. Second hand ones regularly come up on auction sites but they are often so expensive, even second hand, it defeats the whole idea. They seem to be in abundance over in the States as they are in many household furnaces, but not so common over here.
We do have one at work but considering it stands about 5 feet tall and is powered by a rather large three phase motor it may be slightly overkill :roll:
My current thinking is that of using the likes of a blower from a bouncy castle.
I have seen one video of an Australian guy using one as an extractor but that's been the only one.
I don't yet know how much air they are capable of moving or how good they would be at creating pressure, but I think they must be able to produce a reasonable amount of pressure otherwise I would expect the back pressure to stall or bypass the fan when the fat kid gets on. (Only joking about the fat kid of course )
They could be doubled up, allowing for a Low and High setting and mounted in the roof space out of the way,
I often see them cheap locally and a lot of them seem pretty generic so getting a matching pair should be easy enough.
So, for this I now need to find out the following; How much air do they move? How do they cope with pressure? How noisy are they? What would the effect be of doubling them up? And most importantly, is the air and therefore the dust/chips drawn through the fan going to cause problems with the vanes?
Well, putting this into text has helped me organize my normally scattered thought process to some degree.
Any thoughts are more than welcome.
Current situation:
Environment:
Thoughts so far:
