Lightweeder
What is considered the easiest hollowing kit for a beginner please ?
Steve Jones":pdfaaelq said:Lightweeder,
I'm in exactly the same position as you at the moment, I have the RS200 sovereign system which is great if not a little slow for smaller items but IMO no good for larger items. The RS200 hollows with a scraping action and obviously the munro's etc use a cutting action which is quicker when hollowing larger items. I'll probably be having a look round in the coming months at the various hollowing tools available although I was quite impressed with a video on the net of the Pro-Forme in action.
HTH
Steve![]()
wizer":1udl5fhx said:The mini Roly Munro.
Bodrighy":37t2fn5s said:What sort of size hollow form are you thinking of at the moment?
SVB":3v1vqaml said:wizer":3v1vqaml said:The mini Roly Munro.
Tom,
Why the mini tool. There is not much in it price wise and unless one really wants to do hollow froms with small openings then surely the mega is a more flexible tool?
S
Bodrighy":1lfh4oqq said:I ask as small hollow forms can be done without having the expensive tools though they do make life easier. All these were made with a spindle gouge and a tool made from a large Allen key handled and ground to an edge. They are all between 3" and 7" diameter and though not up to Mark & Georges standard it shows that it can be done.
mark sanger":30dj7w0f said:where as a scraper type cutter such as the Kelton's produce small chips and thus are easier to remove. But if you have a dig with the Kelton you will know about it so there is an offset to everything.
Lightweeder":2bd24agd said:mark sanger":2bd24agd said:where as a scraper type cutter such as the Kelton's produce small chips and thus are easier to remove. But if you have a dig with the Kelton you will know about it so there is an offset to everything.
Thanks Mark. So, are you saying the Munro is more forgiving for a beginner? I'll not be doing anything ambitious, but need to have the option available for some simple hollowing.
Bodrighy":1o5w8wwq said:there's a video of one being used here
I have seen a video of Rolly Munro doing a complete bowl with one, very versatile if you can afford it.![]()
