Hi all, been away a while just starting first project since a house move.
I need some advice and help on the simplist way to do this.
Building some reclaimed pine kitchen cupboards.
Ok the sides of the carcasses are frame and panel construction but the shelves/base board are solid pine,well 4" bits stuck together. So what joint would you use to join sides to baseboard, given the solid base will move more than frame and panel side.
any advice would be appreciated
Thanks Alex
Thanks Alex
