Hi,
I have got a scheppach hms 2600ci and have just bought some 27mm waney edge oak boards to convert into tongue and groove boards. This is the first time i have attempted to prep my own timber.
The waney edge boards are 2.4m long but i only need them to be 1.7m when finished . I have staight edged the waney edge boards, and cut into 100mm(4inch) widths cutting all the sap wood off and cut to 1.8m length. If I place a 6ft straight edge along the flat(face) surface there is a bend in it of approx 10mm. When i plane the surface applying pressure on the outfeed table makes the board flat but when it is all planed up there is still approx 7mm bend in it. The boards are to clad a steel framed gate so will pull flat. Over a 6ft length is it what tolerance is acceptable ?
I am hoping to finish the boards to 21mm. I have bought 1/2 cubic m of european oak but don't want to waste it on planer turning it into sawdust!!!
Jon
Jon
