bp122
Expert at Jibber-Jabber
Bought last month from workshop heaven auction sale for £30 (usually retails for around £35), turns out the pitch is not suitable for my uses and is coarser than I can do it justice. So in total it has had one test cut on each side (rip and cross cut)
The handle is really comfortable though, better than the bamboo kind.
The details are here:
Gyokucho razorsaws, the original replaceable blade Japanese woodworking saws, have long been renowned for their cutting efficiency and excellent durability. The latest generation of Gyokucho saws have blue handles made from TPE (thermoplastic elastomer) a remarkable material that is simultaneously hard and resilient yet feels velvety to the touch and affords a superb grip. Rest assured that TPE is an eco-friendly alternative to rubber, and isn’t harmful to the environment as it is completely recyclable.
Seiunsaku are the standard ryoba for carpentry and joinery work, the angle between the centreline and the toothline is carefully calculated to give a rapid yet smooth cut and the heat treatment is optimised for springiness, ie the degree to which the blade can be distorted and still return to its original shape.
The blades of Gyokucho saws are treated using a process called electroless nickel plating, this has three functions. Firstly, it protects the blade against corrosion, secondly it provides a nice shiny mirror surface so you can gauge your cutting angles, and thirdly its low friction properties inhibit resins and sap from building up on the blade - anything that does manage to get stuck to them can easily be washed off with warm soapy water. The teeth are differentially impulse hardened, one by one, bringing the outer surfaces to RC68 or more whilst still leaving the 'root' of the tooth soft and therefore much less prone to fracture - not unlike tiny Japanese sword blades. They are equally happy working in softwoods or temperate hard woods and can, with care and a light touch, be used on exotic timbers too.
Cheers.
- Blade length 300mm
- Overall length 680mm
- Blade thickness 0.7mm
- Pitch 3mm / 8.7tpi XC
- Pitch 5.6-3.5mm / 4.5-7.3tpi XC
- Set 0.125mm per side
- Max depth of cut = unlimited
- TPE handle
- Replacement blade = Part No S-616 (S615 and S-655 are also compatible with this handle)
Cheers.
