and a dished oilstone.
stuartand a dished oilstone.
Yes copper apparently. Is it controversial?Nah, copper. Best you'd do is make it a bit less blunt, no doubt Jacob will enlighten us all shortly. I am sure it's really quite simple if you think about it, hope that helps![]()
Just found the book! This was the local chap. I guessed he'd popped off I hadn't seen him for a long time. I was supposed to be doing some windows for him too!Well I have lived in Wales too and have repaired slate roofs, and yes there may be deterioration of various sorts, but I've never associated it with moss.
Current building 150 years old (Derbyshire) has had original slates relaid, entirely on the north side and partially on the south. The south facing roof gets the weathering from alternating sun and frost, as does the joinery paint work and the rendering.
I think the moss association may be the effect of moss taking root where there are existing fault lines but not necessarily being the cause.
Similarly with other stuff around derelict buildings, even Japanese knotweed - gets blamed for causing the dereliction but in fact is merely occupying space/gaps already made available by building collapse, lost mortar etc.
Had a long chat with local expert whose name I've forgotten (I've got his book on the subject somewhere) who said the same sort of thing when we were looking at tree root damage and possible court case.
But moss can block gutters.
Make of it what you will? What else, except that I was right?
Even worse if there is no moss and water gets straight in more easily, followed by frost..... micro crevices and enlarges them.Thus weakening whatever the moss is on, if the moss is holding water and the water freezes, this splitting effect is worsened,
I've rooted around and removed acres of old glass from buildings over the years, including crown glass 100s of years old from deserted moss covered buildings and have never ever seen moss or pitting on any of it.*......
If moss grows on glass for along time ( many years ) it microscopically pits the glass, glass is not known for having surface fissures.Next time you see a deserted moss covered building with any windows, if you can, root around to find some glass with moss on .remove the moss by simple rubbing, wash to remove dirt. The glass surface is pitted.
Moss hysteria?I’m impressed. A thread about grass hitting 150 posts!
I want to thank this thread, forum and you for your contrary view - What a fascinating plant! I'm going to make a moss garden!It was the moss which got them into a tizzy! Moss hysteria!![]()
And CO2,( to make the bubbles ) hence they are referred to as "carbonated drinks" CO2 in water makes a dilute acid, although I agree, phosphoric is what gives the "tart"ness.No H3PO4 in moss run off ( or in waterheld in the spongyness of moss ) water.Phosphoric Acid
Phosphoric Acid – The tartness of Coca-Cola comes from the use of phosphoric acid.
From that linkWas Pete Marsh a bryologist?
Note the parts about the acidity of water around moss..that does not just apply to sphagnum moss.Sphagnum moss affects the chemistry of nearby water, which becomes highly acidic (a pH of roughly 3.3 to 4.5) relative to a more ordinary environment. The concentration of dissolved minerals also tends to be low. Dying moss forms layers of sediment and releases sugars and humic acids which consume oxygen. Since the surface of the water is covered by living moss, water becomes anaerobic.
