For Sale - Camvac 386 twin motor - NOW SOLD
RogerS
20 Feb 2004
In the eternally wet North
OK - to be 100% accurate it has a sticky label on it saying Tyme Machine but to the best of my knowledge I can't see any difference between it and the real thing. It's not the latest version as you can see from the pictures but it sucks and that's all that really matters.
This is the current spec.
With one to three 1000 watt heavy duty motors, this is the ideal machine for the tool room
› Featuring the CamVac triple filtration system, the GV386 will move your bulk debris effectively.
› Triple stage filtration 0.5 micron. Choice of suction power. Two carrying handles on side of drum and on lid. Choice of hose inlet size: 2.5in or 4in. Capacity 90 litres.
› Capacity: 90ltr. Drum Size: 585mm height x 480mm diameter. Weight: Approx 21kg. Motor Type: Two-stage Direct Airflow, 50Hz AC/DC, 220/240v (110/115v also available). Power: Twin Motor 2200W. Airflow: Twin Motor 108 l/sec (222cfm).
› Cable: 8m x 1.5mm 3 core with 13 amp plug
and costs new between £300 and £400. I'm looking for £200 ono.
