Filling small gaps ?
A
Anonymous
Guest
Hello all,
I'm in the process of building a large pine blanket chest which I will be staining 'Golden Oak' but there are some small gaps about 3mm wide here and there, totally due to my own fault of not cutting the timber acurately in the first place :roll: that I need to fill. What is the best way to do this that will not stand out like a sore thumb after I have applied the stain ?
Interesting reading, thanks, but if I use sawdust and glue will it stain up the same colour as the rest of the chest ?
Thanks, DT.
probably not glue doesn't generallytake stain.
polyurethane glue might.
some woodfillers do.
it would be best to try them on a scrap first.
you need to fill, sand and then stain some test pieces to check.
if all else fails you can stain the piece first and then get a wax filler stick to match the finished colour.
bon chance
aleks
Hi Dry throat
For something as wide as 3mm what I would do is use a sharp chisel and make slivers of the same wood. Put your glue into the gap not on the sliver and tap the sliver home. just be careful when inserting them and wipe excess glue away straight away. When it is dry a light sanding and the stain should be absorbed uniformly across the surface.
Drew
I'll try some of your suggestions on test pieces and see which is going to work out the best, thanks for your help.
DT :)
