face frame question
radicalwood
18 Nov 2004
birmingham
Hi All,
I am currently building 2 built in units from Ash. The question is the face frames are 60" long and I don't have any clamps long enough to clamp the ends on. There are 2 verticals to make door dividers along the length which will be dowled or biscuit jointed together. If I do these first then use those to pull the ends in after glue has set will that work? and would you use dowles or biscuits for the verticals
don't want to spend money on pocket hole jigs or tools :oops: have to save money for the little ones arrival in a couple of months :D .
Neil
The Kreg Mini only costs £15. Or you could make one from off-cuts. If it is only for a couple of frames it doesn't need to last forever.
Neil
I've recently bought some 6' sash clamps because I was fed up with trying to make do on jobs like this. Expensive, but I should have done it 20 years ago.
Anyway to your problem.
The problem with doing it the way to suggest is that the clamping force will not be exactly in line with the joints. Do I understand that correctly?
So my solution in your shoes would be the following. You can simulate a pocket hole with an ordinary small 1/4 router.
On the rear face of the rails, about 15mm from the end, rout a slot, like a mortice, about 3" / 75mm long and, say 14mm deep. A little over half way. Drill a clearance hole from the end of the rail to the mortice. You can then insert a pocket-hole screw into the mortice and screw it in with an electric screwdrive. I find that if I have 3 extensions connected together, it makes screwing inline when the screwdriver is at an angle very easy.
If your face frame is wide enough, two, side by side, would work well.
Steve
You could try clamping a block on the rails, to grip the head of your longest clamp (cramp). Hope you follow what I mean. I wouldn't clamp to the centre stile with any significant force. Even with dowels or biscuits, that's too much leverage on that type of joint.
Brad
thanks guys.
I was a bit worried about the off centre for the clamps and the amount of force to pull the thing together.
George_N thanks for the link did not realise that they did that one. Looks like its out with the plastic.
Steve your right with the forces.
Neil
radicalwood":el6lbr4k said:
have to save money for the little ones arrival in a couple of months :D . Cheers Neil
Congratulations by the way. Enjoy the sleep whilst it lasts!
Adam
Neil,
If you have a flat surface large enough to accommodate the frames, you could use a couple of fences with folding wedges at one end.
Not that i've ever tried it, but could you hook two smaller clamps together so that they pull against each other in the middle.
Just an idea
J
