Mikey R
Hey all, sorry Ive not been on here much recently - since Ive started a new project I though I'd fix that and post a progress thread.
For those interested in such things, heres the spec:
5 strings 34" scale, 46mm nut, 17mm spacing at the bridge
24 fret maple fingerboard with side dots, no dots on fingerboard face
3 pc maple neck
MM style spoke nut dual action truss rod with carbon reinforcement rods
3 pc poplar body, painted finish
Chrome hardware, Schaller 2000 bridge, Gotoh small tuners
The shape is based in Leo Fenders class Jazz bass, slightly modified to make it a little more contemporary:
I bought the timber from the my usual place, John Boddys Timber. To get the haul home, I had to cut the boards down in the car park, when measuring up to glue up the blank I found I was a little too short! So with some head scratching I found if I arranged my template is just such a way I could just about fit it on, with a bit of an odd cut. Heres the body blank after jointing and in the clamps:
I made up a template for the router - using a 1/2 inch bit and a 26mm collar, the template needs to be around 6.5mm undersized:
This allowed me to start with a 30mm collar to take off the bulk of the waste, then come in with a 28mm and finally a 26mm collar.
Ive never seen this done in any photos, but I assumed theres no reason not to, so heres my T10 router mounted in the table with the collar. Theres about 3mm clearance under the ruler:
The body was rough cut with the jigsaw (really want a bandsaw!) then cleaned up on the router table:
The first pass was using a 30mm collar, so we're still 2mm over sized here. Some nasty tearout:
Taking 1mm passes at a time, I got a much cleaner result:
Burnt like crazy over the tricky bits though!
Then followed up with a roundover bit and a bit of carving:
For the forarm contour, I planed the bulk away with the smoothng plane, then finished up the roundover with sandpaper. On the belly contour, I used the drawknife, followed by Auriou rasp (DRIVEBY!) followed by the scraper to clean up, again adding back the roundover with sanpaper.
3 pc maple neck
![309647_10150418578526340_641776339_10324588_1609116876_n.jpg](https://proxy.imagearchive.com/72e/72e477c53ccd3ff8f51c941289c6fdc2.jpg)
![298905_10150411962461340_641776339_10282154_715784687_n.jpg](https://proxy.imagearchive.com/226/226dc722577fdc09e99d6bd8942a21fb.jpg)
![298326_10150418222721340_641776339_10323017_1138297830_n.jpg](https://proxy.imagearchive.com/713/713e20cb263dd5abf55117d54fc4fd4c.jpg)
![298746_10150421944271340_641776339_10339535_1295028345_n.jpg](https://proxy.imagearchive.com/6e5/6e5e6fc4839a2b9f96d63b0eb7c78f28.jpg)
![316051_10150456629306340_641776339_10565844_1254548737_n.jpg](https://proxy.imagearchive.com/136/13640ba5b73869dc988e5f46f8be5ccd.jpg)
![310587_10150456630706340_641776339_10565850_1926169720_n.jpg](https://proxy.imagearchive.com/39f/39f25995a4680c947e956e71544f4675.jpg)
![315705_10150462010111340_641776339_10585887_2029818536_n.jpg](https://proxy.imagearchive.com/8dc/8dcda52ed23fea03923c6bb499b7ea15.jpg)
![313204_10150462008941340_641776339_10585879_1458105485_n.jpg](https://proxy.imagearchive.com/7a9/7a92a111c4ab348b8a8f8a1a2e02fea9.jpg)
![376436_10150462010721340_641776339_10585889_1877861556_n.jpg](https://proxy.imagearchive.com/f53/f532e658a34beb86e29045bbc2cdaa50.jpg)
![310860_10150462164976340_641776339_10586304_2032666221_n.jpg](https://proxy.imagearchive.com/113/113ba3a3f667ce860cf66ddc3c12cd33.jpg)
![388750_10150462249176340_641776339_10586533_241858030_n.jpg](https://proxy.imagearchive.com/db8/db887cf9f4d09a689e4f02e6e2ab9063.jpg)
![374020_10150462251436340_641776339_10586542_1524828709_n.jpg](https://proxy.imagearchive.com/aed/aede4a27e5c289d68c50cd69e17231e9.jpg)
![391794_10150462253541340_641776339_10586548_557732373_n.jpg](https://proxy.imagearchive.com/6ff/6ff6728317fe413b3deec878f1377cf8.jpg)
