Drill bit set - HSS or not?
Richard_C
17 Oct 2019
Cambridge
I've just been given a nice set of drill bits by a friend who was clearing out his deceased father's garage. They are very old - probably 40 years plus - and he lived in the USA for a while.
All brand new, opening the box released the nostalgic smell of the machine machine oil from when they were packed. Steel box says Huot St Pauls, but as far as I can see they specialised in the index boxes not the bits. 1/16 to 1/2 in 64ths. Almost too nice to use, but no point owning them and not using them. But should I only use them on wood I wonder.
Very bright steel throughout, shafts are lightly marked with the size and on the bigger ones 2 sets of letters: US and HS. Its HS, not HSS. So I wonder, was that how HSS was named back then, or maybe still is now in some countries?
Wood drills have a spike point to dig into the wood to stop them wandering. A metal drill will have a 118 degree tip ie much blunter than a wood drill.
Almost certainly will some form of HSS as CS would not last 5 mins.
Tools are meant to be used, it you blunt one then just sharpen it like any other tool.
