Dismanting extractor fan
whatknot
29 Jul 2017
Cornwall UK
I wonder if anyone has managed to take one of these apart?
As I am struggling and don't want to break it
The face place comes off with two screws no problem, the instructions say loosen the screws but leave them in, then pull bottom of grille while lifting
But it does not seem to want to budge
Any ideas appreciated
Yes indeed
I was out grandson sitting all day and rushed the adding of photos, I will try again now
These are the photos I tried to post earlier
Its a bathroom fan, it has a stand off cover, removed by two screws, the instructions say loosen the screws but don't remove them, then pull bottom of grille while lifting
But it seems securely stuck
I did not want to break it by forcing it
If it's anything like my fan, the cover has a lip or cleat it attaches to on the body, so removing the screws further, or just some more vigorous wiggling to slide the face plate slightly to detach from the cleat, before it comes off entirely. Hope that makes sense.
On my fan the screws need to come off completely .
Sent from my SM-G973F using Tapatalk
I did try that and removing them completely
I should say I have done several different varieties in the past but this one is being stubborn
I was hoping someone had previous experience of this one knew the knack of getting the grille off
It really can't be that hard but don't want to break it, its in my daughters home
Possibly the installer used silicone around the tube.
take the cover fully off and try a thin putty knife around the edge.
Thanks for that thought, I don't think so but will check again
This type of fan can be wall mounted too, and you can adjust the angle either way by 5 degrees, (although how you could fit a wall fan 5 degrees out is another matter) but the ceiling fan does move the 5 degrees with no apparent hindrance
Its really annoying for such a simple problem, its in a new build so all the properties around will have the same fans, surely I cannot be the only one to take one apart to clean the fan blade ;-)
