Dining table
Phil Pascoe
UKW Supporter
29 Jan 2012
Shaft City, Mid Cornish Desert
I need to make a dining table. I have a surplus of the tiles in the picture, so I thought I'd get some wany edged oak (or something) to make a surround and tile the centre. (I bought four or five square metres of the tiles for £20 :) ). I can colour milk paint or similar to match the frame to the tiles so it should look good. We go to Morrison'd for breakfast once in a while and they have some (I think) really nice plain oak topped tables with painted frames and heavy legs - that's the look I'm after but my working conditions don't lend themselves to serious work atm, and I didn't want to get involved with turning the legs. I searched on line and found Dave Dalby Woodturning - Home and picked the barley twists. I wasn't too concerned if the finish wasn't perfect as they will be painted. Ordered Monday, turned up today. £61.20 inc. P&P. Wow! Just wow! They are near perfect, and virtually knot free. The coffee table etc. come next.:)
That’s really good value! Shame one has a R/H thread.....
Only joking, you may have to let the wood dry out for a while or the tiles may pop as the plank shrinks.
The oak? will be a surround, the tiles will be on ply. I thought the price brilliant - they're four inch - finished at about 94mm - I dread to think what the timber alone costs atm. I thought I'd get the legs and store them for a month or two before the job gets done.
From experience with a tiled top dining table I would advise against quite strongly . . . wood movement has potential to cause tiles to move/grout to open up . . . and the gaps between the tiles are hard to keep clean - especially with the proximity of food and drink, as well as the possibility of spillages.
I see where you're coming from with the Morrisons tables - I would have thought that a plain, heavy timber top, even if you "cheat" with thinner boards with an under-surround to give a thicker edge effec, would look pretty good.
The table we have, see pic, shows what I mean - it's 18mm Birch ply for the top but has another thickness of 18mm ply about 60mm wide all round underneath to give the illusion of thickness.
How about epoxy instead of grout? You wouldnt want to replace a tile if you broke it though 😁
I'll probably use an epoxy grout. I'm not too worried about expansion - I'll be tiling on 18mm ply. They are floor tiles, they'd take a bit of breaking. (That wall is tiled up to about a metre and runs behind my stove.)
