Chrispy Established Member Joined 10 Aug 2011 Messages 1,974 Reaction score 176 Location Oxfordshire 16 Feb 2024 #1 First experiments with a Diamond drag on gold Anodized Aluminum, letters a 4mm high. Attachments 2024-02-16 001 001.jpg 1.8 MB · Views: 0
Phill05 Established Member Joined 27 Oct 2014 Messages 720 Reaction score 687 Location Derbyshire 19 Feb 2024 #2 Hi Chris, what are you using machine /pantograph I see a little over-run on the lower of the letters try using a wider diamond.
Chrispy Established Member Joined 10 Aug 2011 Messages 1,974 Reaction score 176 Location Oxfordshire 19 Feb 2024 #3 Phill05 said: Hi Chris, what are you using machine /pantograph I see a little over-run on the lower of the letters try using a wider diamond. Click to expand... Not 100% sure but I think it is my CNC it tends to over shoot sometimes, or it may just that typeface
Phill05 Established Member Joined 27 Oct 2014 Messages 720 Reaction score 687 Location Derbyshire 20 Feb 2024 #4 Check out if the motor connects to the screws are tight so you don't get any backlash that could cause over run, what software are you using.
