Nick Laguna UK":228ds6ep said:
Hi woodcarver - My tuppence worth - I'd reckon the extractor hood would then need to placed somehow over the block/surfacing beds if you plan to thickness with the beds in place - the Rojek MSP310 was a fixed bed machine using this design - otherwise all that will happen is all your shavings will compact onto the timber & also royally clog up the machine in a matter of minutes. If you look at the design of every 'lunchbox' thicknesser, they have the hood above for this reason.
Hope this helps,
Cheers,
Nick
This might be so on other machines, but as yet I've almost never used my hood connected to any dust extraction - for starter's it's not even designed to have a extraction system fitted, the flip hood has no extraction port, unlike the later model Kity that copied it, (which is a TOTAL pita to use, eriktheviking has one).
I did once, after modifying it to connect a shop vac to the flip hood by adding a port, but that didn't have enough power and ironically clogged.
I've got plans to contrive something bigger attached to the port using 100mm ducting parts, but this machine has never clogged without extraction, even after planing about 50, 15ft long boards for flooring at least a dozen times each (long story) - no extraction, no clogging - there was at least 8 black bags full of shavings.
The DW1150 is a workhorse despite it's "hobby" appearance - you won't regret it.
Edit - sorry woodcarver - I missed your question - answer is a definitive YES, you will be able to thickness with the tables down once the orange flip hood is removed.
However, honestly I'm struggling to see how much of a PITA fipping the tables out of the way you think it'll be - on the DW1150 - there's just 2 toggle clamps and lift... that's it - it's 15 seconds even if you did it "slow mo movie style"
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
including sliding the planer guide rail out of the way.
The downsides are zero for not doing it and the upsides are you don't have to mess around trying to feed the stock (and collect) from the sides.
Just watch this youtube:
https://www.youtube.com/watch?v=ylEehATEc7I
One last piece of advice - when you fire up the thicknesser - do so WITHOUT the feed roller engaged (they can be disengaged via a handle) otherwise the initial power surge has been known to trip my fuseboard - I was told this by the previous owner and was dubious, but nope, there seems to be just a tad too much electricity draw to have both engaged on initial startup, it's also kinder to the machine.
