Convert a pinned blade
karfeef
26 Jan 2014
Liverpool
Hi all. Is it feasible to grind off the pins from pinned blades to make them pinless? I can't find any pinless locally, so will be ordering online, but will this work in the meantime to practice with?
H
Sent from my GT-I9300
Yes. It will work. The pinned blades are the same length as the pinless ones. They will keep you going till you get a stock of pinless blades.
Sometimes you can just hold the blade over a almost closed vice for support and just tap the pin out.
