clipped ducting
catface
6 May 2007
essex uk
can anyone recommend a supplier for galvanised steel clipped ducting (similar to that by Nordfab). I need a supplier with 225mm (equivalent to 9" diameter). I'm in essex so local is preferred, but if you can recommend someone I'll take a look at whats on offer. Thanks, Catface.
Duct Online list 200mm and 250mm spiral galvanised ducting (is that the stuff you're after?), but not 225 sadly. Got to be worth a phone call though to check if it's gettable. Especially as they're in.....
....er, Essex :lol:
I'd forgotten about CCL :oops:
A quick look at their product dscription pdf reveals this:
Note: Diameters 180, 224, 280 and 600mm will
no longer be available as standard stock sizes
from the end of 2002 in compliance with BS
EN1506.
Looks like 9"/225mm may be a problem then.
