I didn't think you were pushing Rutlands beyond Bessey, I was just adding my own experience comparative to my use of many different types of clamps.I don’t disagree with this at all in fact I take your point entirely.
It’s true that Bessey manufacturer their own clamps and that Rutlands don’t.
But my handling of both Rutlands and Bessey parallel clamps don’t show much difference in quality in terms of “feel”and in actual use that’s all.
But, like I mentioned, time will tell in the longevity department.
In terms of provenance, it’s maybe obvious that the Rutlands clamps will be made in China like most these days, but that isn’t “always” a bad thing.
Im certainly not trying to push Rutlands as a seller of great quality tools, in fact I’ve had to send back, twice, a “guaranteed flat” and “straight “ rule that was anything but flat or straight .
Fortunately, I bought they clamps before I bought the rule, and if I hadn’t I wouldn’t have bought the clamps judged on the quality of the rule.
Nor would Rutlands be my first port of call for most things .
I would be genuinely interested how your Rutlands clamps hold up over the longer term and your opinion on buying more after that use.
You can get the Piher Parallel Clamps from here but they are very pricey .where do you buy them from?
I have 4 x 600mm Axminster parallel clamps and 6 x 900mm clamps from Rutlands. Apart from the colours (and length obviouslyMy parallel clamps are from Axminster. I have always been very happy with them.
Agreed - I have soem Clarke clamps from Machine Mart and they are awful....
Poor quality clamps will have you cursing when something annoying inevitably happens as you try to do your glue up...
ThanksI own Rutlands parallel clamps with the swivel handles (Good for old arthritic hands like mine) and have no problems with them.
I bought 4 Bessey clamp extenders so I can mix and match clamps to suit.
https://www.bessey.de/en-GB/BESSEY-...Extensions/K-Body-parallel-clamp-extender-KBX
I have 8 x 1m clamps and 8 x 500mm clamps and with the extenders I have lots of options without having to pay for lots of longer clamps that I rarely need.
Additionally, this really cuts down on the number of clamps I have to own and it saves a lot of space.
One thing I noticed is that I have to ever so slightly ease (with a file - 10mins work each) the inside of the extenders to make them fit.
This proves to me that Rutlands bars are slightly thicker than Besseys!
I have the Magnusson sash clamps in 600mm and 1000mm lengths, they are ok but not great... They dont stand very well by themselves so make it hard if you are putting a workpiece on top and they are quite poorly made. The clamping heads are not flat. I would not recommend using them for something like a table top glue up without some modification.I also found these - Magnusson Sash Clamp 22 seem to have good reviews, and good cost not in stock though...
ok thats that out then, cheersI have the Magnusson sash clamps in 600mm and 1000mm lengths, they are ok but not great... They dont stand very well by themselves so make it hard if you are putting a workpiece on top and they are quite poorly made. The clamping heads are not flat. I would not recommend using them for something like a table top glue up without some modification.
I started off with these but I am now rather building up my arsenal of parallel clamps as they have more use and generally better. One thing i can say about the Magnusson sash is the clamping power is very strong and they have quite a wide thread meaning using them is quite fast.
