Alf
Roundy Spinny Folks, ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
May I pick your brains a mo'? I'm currently deep in handle making, and it's something I find I use the lathe for rather a lot, but boring the tang holes in line is a pain. Now ideally I'd like to bore the tang hole on the lathe, but my only chuck is a screw chuck and my handle blanks are seldom long enough to accomodate the wastage that entails, and just holding it "in line" has proved to be a disaster. So obviously I'd like a super douper scrolly jawy chuck, but I simple can't justify the expense just to hold the occasional piece of 25-30mm diameter handle blank. I'm really not a turner per se; it's usually spindle work for furniture if it isn't handles, so I wouldn't get much use out of a proper chuck. Is there something out there that might reletively inexpensively solve my problem instead? Am I failing to think outside the box? Any brilliant ideas warmly received; ta muchly.
Cheers, Alf
Cheers, Alf
