50020
This year, I hoped to build a childrens play centre, which would have incorporated a storage area, but my drive project was hindered sourcing materials due to Covid. I never completed the drive until September, as a result, by the time I was ready to start the play centre, and materials for such started arriving, I was out of time and weather. I am hoping to start early next year - but I want my shed back from the plethora of Childrens garden toys!
I have therefore decided to build a small, 3' x 5' shed to store the kids' toys in. The height would be 1800mm, simply because this is roughly what the lengths of 3" x 2" I could easily manage in the car.
I have never built anything before, so this is my first foray in to woodworking [save for a course I did with Chris Tribe in Yorkshire]. It is somwhat rudimentary, but I have learned much from on this forum and also a couple of UK Facebook groups.
So, I have planned the playcentre on SketchUP for Web, and decided I'd use this for the Shed. A few hours on nightshift, and I had a basic frame with a door. If nothing else, this could all be used to dertermine just how much and what timber I would need.
This was the basic idea, but I did change a few things once I got going. For example, the vertical in the middle of the long wall, I decided to double it up when building the walls, you will see what I mean.
I started of making the base. I had some 4" x 2" lying around, so I built a 900mm x 1500mm frame. This was a simple affiar with a cross brase piece in the middle to support the floor, which is made up from 22mm OSB.
I had to buy a full sheet of 22mm OSB and cut to size. I used a circular saw, with a straight piece of whitewood as a straightedge clamped to the board to cut the 900mm x 1500mm floor.
Once the floor was cut to sice, this was fastened to the 4" x 2" frame using screws, although this next photo was taken before I had drilled/screwed it together.
Once the base was complete, I decided to start working on the 'walls'. Starting with what would be the back wall, I built an oblong frame with the outside dimensions of 1800mm x 824mm. This would allow me to double up the verticals, as the 2" of the 3" x 2" is nominally 28mm. 28mm + 28mm + 824 being 900mm. I am not sure if this is overkill, but looking at sheds you can buy, these are build from timber much smaller, and definately without doubled up verticals.
Once I had completed the back wall, I tried a dry run of how I expected it fit to the base. Have to say I was fairly chuffed it was coming together how I had planned it in my head! You will note my ommission of a cross-brace (don't know what they are called). The very good reason for this missing is I forgot. I had already fastened the two strengthening pieces on the outside of the frame by this point, so decided not to bother. Whether this will come back to bite me on the buttocks remains to be seen!
Once the back wall was complete, I marched on with the next. This is the reason the centre vertcal is made up of two 3" x 2"s.
If it was done in one frame with one centre vertical, I wasn't sure how I'd fasten the horizontal parts to just one vertical becuase after screwing one side, there is no way to scre through to secure the other horizontal piece? Does that make sense? I don't like the idea of screws going through th eheels of joints.
I also made it in two halfs to make it easier to manage. Here you can see the two halfs clamped together ready for screwing together.
The remaining wall sections were completed in the same way. The front section though where the door will be, while efectively the same as the back wall, there is no bottom to the frame, as I would trip over it. There is a piece of scrap timber though keeping the space correct and square though, shown below. It's even painted white, not for clarity - it just happened to be so!
