CCBB Bandsaw Blade Guard
bernienufc
24 Nov 2013
northumberland
Hi
I have just acquired a Perform CCBB Bandsaw which is need of some work to get back to scratch.
I have the manual (thank you Axminster) for any parts I need like the bearings, but I have a question about the setup.
On my hobby Bandsaw the bearings are 90 degrees to the blade, in other words the blade rests against (or nearly rests) the roller edges which makes perfect sense, but on this model the blade sits against the faces which as you can see carved a groove in it. So is there a mod or is that the way it needs to be?
Many Thanks
Malc
On my hobby one the blade touches the bearing when under pressure especially as the gap is so small when setup, but no matter how hard i try i cannot for the life of me understand this setup....that said there must be hundreds of these out there so maybe its just me.
Thanks for reply
Its meant to run about 1/4 of the was across the bearing so if it touches it spins the bearing, looks like its been set up wrong, get a new bearing from Ebay etc it should have a number on it.
Lots of bans saws have this arrangement and they work fine.
Thanks Pete, will do
