Can a burnt out drill be repaired
Max Power
26 Mar 2007
County Durham
I have managed to burn out a L ion Makita drill. Can they be repaired economically or is it time for a new one ?
If its brushes or a motor they can be replaced. Check with your nearest repair place and get a quote. But it might be quicker and cheaper just to buy a new drill body.
Just had my Makita 18v combi drill motor replaced £50. Only did it because it's the 3 speed all metal gear and chuck etc.
I don't know about Makitas, but I looked in to repairing a Black and Decker corded drill.
As previously stated, the only bits worth replacing were the brushes. Any other motor component cost more than a brand new replacement drill of the same type. Crazy.
When the rotor on my big corded drill had burned out at work last year I did somr research. It would have been possible to rewind the rotor but it is a very costly affair and there are only a few companies in Europe that would do it. A readymade new rotor wasn't an option as the maker had gone out of business 50 years ago. In the end I discovered that the collector was worn out as well so that tipped the balance in favour of a new drill.
Now you have a drill that was made by a mayor manufacturer with a service network and avaiable spare parts. I would ask the nearest Makita repair shop what they rekon a repair would cost. Then I would decide. If the drill isn't Makita's cheapest model and otherwise in good condition it is likely worth a repair. Otherwise not.
