Brass infill mallet?
Doug71
28 Aug 2016
Yorkshire
I've just acquired this, Google tells me it's a brass infill mallet? Is it just a mallet with a bit of extra weight, it weighs about 2lb.
I can't see any makers marks and it doesn't really look that old, are they a common thing?
I shall be putting it to work tomorrow, it's certainly much prettier than the black rubber dead blow mallet I use at the moment :)
Similar method to a hide mallet with the metal centre for better weight, looks like replacement faces could be easily replaced. Seems legit.
Doug, I have two versions with similarities. In essence what they aim it is creating a mallet head with maximum mass (for the specific task) in as small a head as possibe (for ease of use).
The first is a modified Veritas, and the second is a brass infilled morticing mallet (the smallet mallet is for bench chisels) ...
What all have in common are UHMW faces and shopmade ergonomic handles.
Regards from Perth
Derek
Unless ur a square ....lol.....or into engineering then the Thor mallet comp ...
British and going for as long as I can remember....copper n hide or a double ender.....
have a few but rather like the 5lbs'er.....still good after 40 years of use and the handle is orig and still tight.....
I have a couple - no makers names - guessing pre WWI
replacement faces on one of mine not as easy as looks because the boxwood infill goes right thru and the handle thru that - this stopped me investigating the other
however they do look good
clogs - your avatar is the Studley tool box - there's a fine one of these in that
I have an old masons mallet , round like a carvers mallet, with a large head and tiny handle. It has a dovetail insert at the top made of lead to give it a bit more heft, though I'm not sure it needs it. :unsure:
I was going to attempt replacing the faces on mine but found a couple of Youtube videos showing some have a full wooden head as you describe so putting that job on hold for now..........
