nickson71
I'm just thinking about on of my jobs for the new year and it's building a bench............
I'm going to be using a recycling a couple of lab benchs I got from work
the two tops (1inch thick) will be ripped in to 6.5cm widths and these will be glued up to give a 6ish cm top after clean up. The rest of the lab benches will be pulled apart and cleaned up and laminated together to make the frame with anyother timber that maybe required.
I'll be only having one vice on the front at the left hand side .... the question I've got is where do I put the dog holes as I've now discovered I've no idea where to put them ...............
In most of the picture I've seen the dog holes are in-line with the tail vice but I've no room for one of these
Ian
Ian
