• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold AXMINSTER BANDSAW SBW4300
Mooeee
28 Aug 2006
Hertfordshire
For Sale: Axminster Plus Industrial bandsaw 2HP 1.5KW, Maximum width cutting 410mm and 300mm depth. 45 degree table tilt, footprint of this Bandsaw is 680 X 450.
Overall Table size is 600 X 450 including a mitre slot to the right side of the blade.
It is in great condition and has been well looked after, I have just changed the blade guide bearings and it comes with another complete set of brand new guide roller bearings. Shown in one picture is the fence although I have removed it and rapped it up, and also removed the blade that was on it.
The wheeled base is included with the machine.
It is a very well made and robust bandsaw. Blade tension is seen through a small perspex window on the top door and another small window on the front of the machine allows you to check the tracking of the blade.
It has a braked motor, a safety cutoff switch located on the top door and with interlocked top & bottom doors that isolates the motor when the doors are open. the quick release blade tensioning lever makes blade changing quicker and easier.
16Amp plug fitted
Two 100mm dust ports, one on the side the other on the front of the machine.
If anymore info or pictures are required please message me with email and I will get whatever is required sent over.
I do have around 9 blades, that I will sell separately.
Machine is about 1850mm off floor, in the base it comes in around 1900mm, weight is approx 150kgs, cast iron wheels 430mm/17"
Machine with Base £0000
All the extra blades £000
Collection would have to be in a van as this will not fit into a hatchback.
IMG20230604125313.jpg IMG20230604125338.jpg IMG20230604125500.jpg IMG20230604125535.jpg IMG20230604125344.jpg IMG20230604131059.jpg IMG20230604130738.jpg IMG20230604125429.jpgIMG20230604125541.jpg IMG20230604172346.jpg
Hello again,
I've measured and there is just enough clearance if I take the saw off the trolley (you did measure it accurately for height on the trolley, didn't you?) and put it on some 9mm ply to use that as a skate, so could take it from you if still for sale. I've made space to fit it so we're on!
