Adirondack plans (sketchup)
13 Jul 2015
Wales
I don't suppose anyone has sketchup plans for an Adirondack chair do they?
I've come across Norms plans as a PDF which is great, but it would be even nicer to be able to print out full scale templates :D
the fine woodwork plans are cleverly scaled making the slope and the arms easy to draw out. I think you just measure using a caliper and times by 3. if your making one then the other bits can be made directly using a big compass. if your making many make a template for every shaped bit.
I don't think it's necessary to print perfect full plans as accuracy is only required between certain pairs of components(like the slopes and the legs. the arms only need to look similar)
