A real good option for fixings on box iron
Ttrees
Iroko loco!
18 Nov 2012
In me workshop
Arrgh!, I seen this solution randomly just pop up, the day after I needed it :ROFLMAO:
so might as well share and perhaps suck it up a bit.
I'll give the link of the "short" below, but will explain for ye folks who won't watch youtube
Starts off with grinding a bolt head round, for welding clearence, and the washer is ground a wee bit also.
The fit for the nut is close and needs a tap
The washer keeps the nut suspended for welding
And removed after the tack
So simple, and much nicer job than drilling through the box for a hex keyed bolt,
which I will never un-see forevermore.
Hope you've all enjoyed my tale of I could'a told ya that :poop:
Here's the link to the 30 second video
All the best
RIVNUTS......they need to be prop fitted....not too loose or too tight .......I use a drill n reamer......
plus not every one has a TIG machine......
Dont try doing this weld nut procedure with st/st......50% will end in tears.....lol......
if it has to be structuraly strong, weld the nut to a plate then tac weld the plate to the inside of the tube.....
or a much better way is to weld a heavy plate inside the tube then drill n tap it.........
