I've already pruned a few dozen from this young tree.
Every year a farmer near us brews a barrel of cider then invites all the neighbors over for a barbecue. I almost remember the first time I went! Didn't realize he uses a whisky barrel purchased "new" for each event. That year there was about half a gallon of whisky still in the barrel. I remember the first 30 minutes and the next afternoon......Cidereeeerererererererererererereererer hic!
Put some pics up if you can please Cozzer. Most single variety trees are grafted just above soil level but 'family' trees often have an interscion between the rootstock and the chosen varieties. If there's a graft near soil level and another at the fork then the buds that are breaking may be something totally different.
On another note, Bramley is so vigorous you may find it difficult to stop it taking over and the braeburn may fail. Partial ring barking may be required to restrict the bramley
Ok, bit surprised it isn't on a short stem, but it looks as if you've got Bramley on the right and braeburn on the left. Given the thickness and angle of the Bramley stem I think you'll struggle to keep both alive. I'd rub off the buds below the graft, train the stem upward and just keep the Bramley if you've the room, ours is 25 ft across and 20 high after some serious pruning when we moved here.
Thanks for the info, Tris.Ok, bit surprised it isn't on a short stem, but it looks as if you've got Bramley on the right and braeburn on the left. Given the thickness and angle of the Bramley stem I think you'll struggle to keep both alive. I'd rub off the buds below the graft, train the stem upward and just keep the Bramley if you've the room, ours is 25 ft across and 20 high after some serious pruning when we moved here.
As Niemeyjt mentioned they need more than one pollination partner but as long as there are any other apples, including crabs, within a quarter of a mile then you'll be fine.
Can recommend Walcot nurseries if you want a good replacement
Hello
It looks to me like you have planted it too deep. The tree should have a stem and a root system below ground. Because it is planted too deep it is spouting out too far up the point where the different apple cuttings were grafted.
